Salta al contenuto principale
The Kindle 4 has 4 models released September 28, 2011.
Why wont my kindle Charge
Hi,
My kindle has been out of use for a while now. Last time I used it it was faultless. I have pulled it out to load a book and it is showing the charge picture on the screen. When I connect the charger it illuminates with a orange light but then after 30 seconds changes to a green light. After being on charge for a full night it is still showing the charge picture on the screen and it will not turn on. HELP
Questa è una buona domanda?
Punteggio 2
2 Commenti
tried 2 different chargers and it will not accept a charge
da
I finally woke it up and it is now charging. Thanks for the help.
da
Aggiungi un commento
2 Risposte
Soluzione prescelta
danandlozza04, if your Kindle after a long time charging still does not take a charge, then it is possible that your battery has been discharged below its threshold to take a charge. This would require changing the battery. Here is a decent video about the replacement. The battery is available at multiple places of your choice.
Punteggio 3
Try leaving the power button pressed for a LONG time. Sometimes kindles have to be reset. If 90secs have passed and you don't see anything different then let us know. Post your results either way :)
Punteggio 1
1 Commento:
I have held the power button until it blinks twice then shuts off again - the screen still shows the battery icon - this is after I have charged all night - what gives?
da
Aggiungi la tua risposta
danandlozza04 sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 3
Ultimi 30 giorni: 22
Tutti i Tempi: 11,231
