Salta al contenuto principale
This model is essentially a rebadged Daewoo Lacetti marketed for the US from 2004 to 2008.
What is making the rattling noise on startup?
Every time the car is started, mainly when it's cold it makes a loud rattling noise for a while and then if you rev up the motor it tends to go away.i changed the tensioner pulley thinking that would solve it but no luck. Please anyone have same issue help!!
And it's not low on oil already thought that.
2006 Suzuki Forenza
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
My toyota lj70 with 1kzt 3.0 engine also does that and it s also the blue smoke coming from the exhaust. After reving it s all good :( pls help. I might think it s because of the turbocharger which is worn.
Punteggio 0
Aggiungi la tua risposta
William Sykes sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 8
Tutti i Tempi: 810
