Salta al contenuto principale
Released on October 23, 2012. Core i5 or Core i7 Processor. Apple Fusion Drive.
208 Domande Visualizza tutte
Domanda Chiusa
initialize and format SSD before installing in MacMini late 2012
Should I initialize and format my SSD before installing?
I have a NewTech Voyager device.
Plan:
Clean up existing internal HD
Use CarbonCopyCloner to make a copy of the existing internal drive
Plug in the SSD and clone from the existing HD
Install SSD in MacMini late 2012
set startup volume to Internal SSD
Thanks for any advice/direction
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Here's how I would do it:
Put SSD in enclosure. Connect to Mac.
Initialize and format SSD using Disk Utility: GUID and Mac OS X Journaled.
Restart MacMini in Restore Mode; or by holding Alt/Option and selecting Recovery.
Go to Disk Utility when in Recovery or Restore Mode.
Select your HD, perform Repair Permissions + Repair Disk a couple of times.
Select your HD, choose Restore; choose your original HD as source and SSD as target. CAREFUL, don't mix up source and target on this step.
Once done, select your SSD and also perform Repair Permissions and Repair Disk.
Turn off machine. Swap drives. Et voilà.
Punteggio 3
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 19
Tutti i Tempi: 4,144
