Why does my phone keep vibrating for no reason
My phone keeps vibrating usually 2 quick vibrations after one another fo no reason. This keeps happening while on standby . I have tried everything but cant seem to stop it.
Questa è una buona domanda?
88 Commenti
Hello, Could you give a bit more detail? how often, while sitting on something or your pocket, have you tried to turn vibrate off , is resetting the phone an option?
da Goulithum
Found my own solution i did remove the battery cleaned the contacts and put out hte micro SD card put it back in and started it, the buzzing went off. might be so the SD card was not 100% in contact. :) did also remove manually all updates and forced push services for updates on the android os.. that is just stupid takes up too much space on the little phone ;).
da silverpil77
Just reset android 3 or 4 times and it works fine
da cody kamminga
hi guys my phone do the same.
da emmanuel Bathusi
my phone has been doing the same recently. i recently reset it. now we wait.
da escrossley100
Mostra altri 83 commenti
