Salta al contenuto principale
Quinta generazione dell'iPhone. La riparazione di questo dispositivo è semplice e richiede cacciaviti, strumenti di apertura e pazienza. Nero o bianco, GSM/CDMA / 16, 32, o 64 GB.
2193 Domande Visualizza tutte
Domanda Chiusa
iPhone 4s iPhone 3 touch microwaved? after water damage
hi everyone
i just supidly in one rainy morninig tried to dry up my iphone 4s in the microwave for exact 2 sec and then took it out right away as i saw some blink light, then i dried it the normal way, everything is working well except the touch function, no matter what i did cganged to a new screen the same problem persisit, could it be a responsible transistor burnt on the motherboard how can one fix , where to localise it
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
On the image I have put two red circles where most of the components for the touchscreen are located. I would check in those areas and see if you can notice any damage.
Punteggio 2
hi
it helps alot to be sure that its a proplem with the board since i saw a blink when i microwaved it, now the problem is certainly located on the zone shown on the second circle of the picture below . do you think there is something to do about that to be fixed,
thanks
Punteggio 0
1 Commento:
Most things can be fixed. It would be just a case of identifying the faulty component and replacing it.
da
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 106
