Salta al contenuto principale
D1760-2 DECT 6.0 Cordless Home phone with caller ID.
190 Domande Visualizza tutte
T-coil uses on uniden
What is the t-coil used for?
Questa è una buona domanda?
Punteggio 2
2 Commenti
The answer by" Knows a little" with the website http://www.hearing-aids-wizard.com/t-coi... leads to an Asian !!%@ site. You may, or may not, want to fix this. I hope you will!!
da
When I go to dial the phone, it beeps 4 times before I hear a dial tone. How can I removed the 4 beeps?
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
It has to do with hearing aides. From what I understand, it allows people with hearing aids to use a magnetic signal instead of just sound to communicate with their hearing aides. Hope this helps.
Punteggio 0
My moms uniden cordless phones won't keep charge? is something in menu setup wrong...
Punteggio 0
1 Commento:
It could be the battery. The older style batterys don’t last long and even though they show a good charge won’t last more than a minute
da
Aggiungi la tua risposta
Donna sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 57
Tutti i Tempi: 8,199
