Salta al contenuto principale
Production of the fifth generation 2010 Subaru Legacy began the last week of May 2009 at the Indiana location, and was unveiled at the 2009 New York Auto Show.
How to added transmission oil
how to added transmission oil
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
boris, not an easy thing to do. Going to be tough without a lift or a pit. There is a fill plug on the back of the transmission. Remove the plug and put a finger in the hole. If it doesn't come out with fluid on it, it's low. To refill, fill it up in the hole until it comes out. Remember to use CVT fluid only
Punteggio 3
It should be up to the bottom of the hole somewhere around 100 degrees Fahrenheit.
Punteggio 0
Aggiungi la tua risposta
boris sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 32
Tutti i Tempi: 17,847
