Salta al contenuto principale
L'Apple iPhone 5s è stato presentato il 10 settembre 2013. La riparazione di questo dispositivo è simile a quella dei modelli precedenti e richiede cacciaviti e strumenti di apertura. Disponibile nelle versioni GSM o CDMA con capacità di 16 , 32 o 64 GB nei colori Argento, Oro e Grigio Siderale.
3530 Domande Visualizza tutte
Domanda Chiusa
Changed battery and charging port but still wont charge?
Hi there
I bought an iPhone (Just been factory reset) a few days ago and it seemed to be working absolutely fine once it ran out of battery I tried to charge it. Came up with flashing battery and plug with lighting on the screen when I tried powering up.
I do phone screen repairs so I changed the battery and the charging port however it still wont charge. I have tried different cable etc so it's not that. I have tried connecting to itunes and it says device is not supported.
I have seen that there is a small IC chip on the iphone 5 which controls the amount of charge and it the past these have been faulty. Although I have never seen one about a 5S.
Is there anything else I can do/Check?
Thanks
Matt
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Matt Rimmington, sure sounds like an issue with the power management IC. I suggest that you check all components around the U2 IC and see if you are either missing some or if they are shorted out.
Punteggio 2
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 78
