My blackberry z10 only the red LED lights
my blackberry z10 does not turn you connect the charger and only the red LED turns on and does nothing more. Remove the battery and measures just 2 volts. After charging for more than two hours measured again and the same. according to the specifications of measuring 3.8 volts, if anyone can help me with that
change the software but can not because the PC does not recognize
the model is STL100-3
Questa è una buona domanda?
1 Commento
very similar situation:
blackberry z10 have shut down suddenly and will not turn a more. Only the red LED lights up, but makes two flashes every 30 seconds. Replacing the battery gave nothing. If anyone can help me with this.
a computer does not recognize the device in any way.
STL100-1 model
da Yura Bernstein
