Salta al contenuto principale
L'Audi A6 è una berlina di lusso prodotta dalla casa tedesca Audi AG, ora nella sua quarta generazione. Tutte le generazioni dell'A6 offrirono o trazione anteriore oppure la trazione integrale basata sul differenziale Torsen, commercializzata da Audi come Quattro.
Alternator or Voltage Regulator? Burned two batteries in a week.
The 1996 Audi A6 Quattro cars battery gauge will jump up under acceleration but doesn't seem to hold charge even after long periods at high R P Ms dies at idle I had it tested at AutoZone they stated must be Alternator but the Voltage regulator much cheaper part and a fix I could manage, the alternator not so much . Any information as how to diagnose one from the other would be greatfully welcome.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione prescelta
You can test you alternator with a voltage meter . With the motor off get a reading it should be around12.6v then with the motor running it should be 14.2v but if its over 14.6v you have a issue with regulator. If you've burned out 2 batteries in a week your looking at the voltage regulator but most regulators are inside the alternator. If moneys an issue try an auto wreckers . Cheap place for parts and your dealing with an old car so why not put an old part on . Probably last as long as the car and if it doesn't you can get 3 or 4 alt at a wreckers for the price of a new one. One of them is bound to outlast the car.
https://www.youtube.com/watch?v=LGB6ZEjG...
this is a good video to show you proper test
Punteggio 3
Keith, this should explain how to check Alternator vs. Regulator.
Immagine
Immagine
Punteggio 1
Aggiungi la tua risposta
Keith sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 3
Ultimi 30 giorni: 17
Tutti i Tempi: 3,482
