Salta al contenuto principale
Repair guides and support for tablets produced by Lenovo including the ThinkPad tablet line.
468 Domande Visualizza tutte
it would not turn on
Hello, my name is Sara. I've lost my lenovo yoga tablet 10 60046 on the floor, and after that I do not get it started. tablet flash and vibrate when it is on the charger, but otherwise it does not. I have tried to keep the start button several times in a few seconds, but it will not turn on at all. I was wondering if you could help me fix this problem?
Lenovo Tablet 60046
Questa è una buona domanda?
Punteggio 2
1 Commento
Exactly the same problem and symptoms... Any solution found Sara??
da
Aggiungi un commento
3 Risposte
Soluzione Prescelta
First hold Power button and down button for 10-15 seconds at the same time . This should put you into a selection menu . Select Reboot by Volume Down and press Power to reboot.
Hope this helps
Punteggio 2
Shock damage to internal components does not usually end well. I would suggest taking it apart if you can and look for obvious damage and replace anything you find to be broken or faulty. You could also get in touch with Lenovo and ask them to repair it for you. It is very unlikely to be an easy fix...
Punteggio 1
brother my name is hassan and im from pakistan i have damaged my display strip please tell me where to buy it from.
Punteggio 0
Aggiungi la tua risposta
Sara sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 9
Tutti i Tempi: 614
