Salta al contenuto principale
Released June 2006, the Dell Inspiron 530 is the first desktop in the Inspiron product line.
14 Domande Visualizza tutte
Domanda Chiusa
Computer will not post
Computer has power but will not go through POST process. I don't hear any beeps at all. Monitor says "Auto detect power saving mode." Monitor is working because I plugged it into a different computer.
Questa è una buona domanda?
Punteggio 0
1 Commento:
It does not POST or your do not have any video? This just started or did anything happen to your computer? What have you tried?
da
Aggiungi un commento
1 Risposta
A computer that will not post suggests two possible causes:
1) Bad motherboard;
2) Bad power supply.
I have made an assumption: that you have only one video connector on your system. If you have more than one, try connecting your monitor to other video connectors.
Also, you do not say if the fan starts when you attempt to start the system. It usually starts at high speed and then quiets down.
Punteggio 0
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 153
