Salta al contenuto principale
L'Apple iPhone 5s è stato presentato il 10 settembre 2013. La riparazione di questo dispositivo è simile a quella dei modelli precedenti e richiede cacciaviti e strumenti di apertura. Disponibile nelle versioni GSM o CDMA con capacità di 16 , 32 o 64 GB nei colori Argento, Oro e Grigio Siderale.
3530 Domande Visualizza tutte
Domanda Chiusa
Both cameras are displaing colorful lines in display.
Both rear & front cameras are displaying colorful lines. Sometime lines disappears. In short they are out of order. My set is almost new and still secured from any damage. It never droped from my hands and reseted it as well. I'm really worried about it. Please somebody guide me regarding this issue. I can show images reflecting the issue. I have also shown it to a professional but he is asking too much money and not guarranting that it will become ok. Is there any utility to repair it or guide me so that i'll repair it myself as I'm having essential knowledge of hardware.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Considered that display is not failing, restoring to factory defaults may resolve this issue. If the issue persists even after the factory restore, it may increase overtime and a display replacement is inevitable eventually.
Before restoring to the factory defaults you may consider hard resetting it. You may press the home and power button at the same time while the phone is turned on. As the pone turns off and then Apple logo shows, let go the pressing of power and home quickly. If this didn't resolve, I recommend you to attempt factory restore.
You would also like to check how much space you do have in your iPhone. If you are running out of space, prefer deleting some not needed contents.
If it is most definitely the display issue, you can have it here at fraction of the repair cost. Hope it helps.
Punteggio 0
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 41
