Salta al contenuto principale
Released June 2014, identified by model 635.
Bad Power Button Connection on Nokia Lumia 635
I can tell that it won't turn on for this reason. If I plug it in, the screen is still on, and it turns on when I get a notification. I've made this work for a bit by extending the time the screen is on but this massively drains my battery. How would I fix this? It seems petty to take into a phone repair place.
Questa è una buona domanda?
Punteggio 4
Aggiungi un commento
2 Risposte
Risposta Più Utile
Did your phone get hit or dropped?
The most probable reason for that seems to be related to the inner pressure point connector of the power button (located right at the motherboard). Take it anyways to a technician: He would probably tell you that it needs to replace the motherboard of your phone, as it the integrated connector it's difficult to solder again (or doesn't have the time/skill/part for it).
Hope it works again!
Narmith
Punteggio 1
1 Commento:
Narmith!....i have the same problem but I think I dropped it ..how much does it cost to repair it?
da
lumia 635 power baton bord not warking
Punteggio 0
Aggiungi la tua risposta
gobstopper2 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 1,053
