How can I get the charging port replaced?
how can i change my charging port on my nexus 6 ???
Questa è una buona domanda?
arthur1870, it is soldered to your motherboard. You will have to disassemble your phone, desolder the old one and then resolder a new connector.Not an easy task since the contacts on the port as very small. Unless of course you have the tools and skills to do that. Use these guides to work on your phone.
This is the port you need: http://tinkersphere.com/electronic-compo...
Mine jiggled off since I connected and disconnected the cable so much. You need to desolder the old connector with solder wick and resolder the new one with a soldering iron.
In case anyone finds this in the future, the photos on this link don’t seem to correspond to the Nexus 6’s charging port. The nexus 6 charge port is a flangeless, reverse-mount, 5-pin SMD + 4 DIP legs port, which I’ve only found here: https://www.youtube.com/watch?v=byJWKr9J... (this video identifies the port, they sell it on their website)
Additionally, you can see how the PCB looks like without the port here: https://www.youtube.com/watch?v=RT3a8haH...
This one looks very similar but has flanges, which might make it not fit correctly in the case: https://www.amphenol-cs.com/micro-usb-10...
EDIT: This one might be right as well, but has less shipping options: https://www.amazon.com/Charging-Motorola...
Ultime 24 Ore: 3
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 5
Tutti i Tempi: 5,763
