Salta al contenuto principale
Quinta generazione dello smartphone android al top di gamma Samsung, rilascaito l'11 aprile 2014. I miglioramenti rispetto alla serie successiva comprendono lo scanner impronte digitali, la fotocamera aggiornata, lo schermo più grande e la resistenza all'acqua. Disponibile in quattro colori differenti: nero, blu, bianco e oro.
577 Domande Visualizza tutte
What is up with my screen?
hi could you tell me what is up with my phone its a samsung s5 i dropped it yesturday and my phone screens gone all fuzzy i carnt see anything on my screen but the touch is still there?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Hi,
Faulty Lcd, will more than likely need replacing. :-)
Punteggio 1
1 Commento:
only had the phone a few month brand new from shop there is no crack on my screen and the buttons are lighting up and the touch is still there :/
da
Usually when a phone is dropped, it cracks only the glass (pretty much the lens for the lcd). It sounds like it fell hard enough that it made the lcd malfunction. If there is no visible crack on the lcd, it could just be the wiring inside. This is usually not the case though. You'll have to buy the lcd and glass combo online. I think they're cheapest on Amazon.com at around $130, last time I checked. As for the touch still working, there is another part called the digitizer. This is what senses your fingers. It's a lot more flexible and resilient then the lcd and glass. Thankfully, that also extends to impact protection. :) Hope this helps and good luck!
Punteggio 0
1 Commento:
More flexible and resilient THAN the LCD. More THAN, less THAN, rather THAN, etc.
da
Aggiungi la tua risposta
kimberleywindlenew sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 5
Tutti i Tempi: 1,681
