Salta al contenuto principale
The drone is a Wi-Fi capable and it's equipped with a built-in HD camera. It is used for taking pictures and filming. Model number: PF722000
Unstable Take-off and crash
Hi, initially when I hit the take-off button the drone used to hover. For some reason now it spins and tilts to the right ...and crash lands
Questa è una buona domanda?
Punteggio 4
Aggiungi un commento
3 Risposte
Risposta Più Utile
Verify your helices, My do the same and I change, be attencion on the jelices open in the center and others is not, the close ones maybe put in silver pin above.
Sorry about my english
Punteggio 1
1 Commento:
André, o que vc fez pra resolver o seu? O meu não fica mais parado, ele fica andando sozinho...
da
calibrated wrong if the trim is out of wack it will do that
Punteggio 0
1 Commento:
How do you fix the trim?
da
Did you ever fix your problem? Dealing with the same thing. I was flying my drone when the prop flew off and now it does not take off and hover at all
Punteggio 0
Aggiungi la tua risposta
Doberman sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 2,310
