Salta al contenuto principale
How do I get the ipod to unlock?
The hold button appears to be broken in the locked position. The switch moves but does not unlock the ipod.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
4 Risposte
Risposta Più Utile
Well....
A couple of reasons why this may happen:
  1. the little nubs on the hold switch are broken off. It is housed on the front panel.
  2. the hold switch itself is broken off. It is housed on the logic board.
Either way, it seems like you need to open up your iPod, unfortunately.
Unfortunately, these machines are NOT easy to get into. They have very delicate clips around the outside that make getting a new rear panel almost a necessity whenever replacing anything else. Just wanted you to know beforehand, so you're not surprised.
Take heart, it can be done! Good luck!
Punteggio 2
How do I unlock iPad mini 4
Punteggio 0
I sm asked for a combination
Punteggio -1
1 Commento:
This isn't really an answer. Please delete this or edit it to answer the question.
da
I forgot my code and now can not unlock my iPod ????
Punteggio -1
Aggiungi la tua risposta
Jennifer sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 8
Tutti i Tempi: 4,427
