Hey hunter iverson, this could just be an iOS issue or a hardware issue. Here are some things you can try:
-Reboot your device (turn it completely off then turn it back on)
-Test the audio by going on the Safari and try to listen to music to see if it works.
-Test audio on other apps.
-Do a quick hard reset. Press and hold the power and home button of your iPod for about 10 seconds. Once the iPod turns off then back on, let go then test the volume.
-It could be a corrupted iOS so restoring your device might help.
If nothing mentioned above works, then do the following hardware fix:
-Select your certain iPod Touch from here and then do a quick tear down and reassemble it back. Then check to see what works.
-Let me know how it goes.
Votato
Annulla
Punteggio
Annulla
Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
