Salta al contenuto principale
Sesto modello di iPhone Apple, annunciato il 12 settembre 2012. La riparazione si fa in modo simile alle precedenti versioni di iPhone e richiede cacciaviti e strumenti di apertura. Disponibile con tecnologia GSM o CDMA, con 16, 32, o 64 GB, nero o bianco.
2522 Domande Visualizza tutte
iPhone 5 boot loop with brushes in different colors, vertical, horizon
Hi,
i have search on this Forum and look for answer but i have nothing found.
After a crash on the ground my iphone is in a boot loop with very strange effect.
The iphone was not detected on itunes. I try the Recovery Mode and DFU Mode. Nothing helps.
Please, look at the pictures:
First of all normal Boot bei press the power button:
Normal boot
Then one second after the normal screen with apple logo you see this:
special effect
special effect
I hope you can help me but I think it is an hardware error. Can you fix it?
Best regards Benny
Update
UPDATE:
I have change the Battery und the Screen but still the same error.
Here I have saw on youtube a video. This is similar
Video
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
3 Risposte
Hey Benny, did you check to see if all the screws, during the digitizer replacement, were all in the correct place?
-Let me know if this helps.
Punteggio 0
Hey iApple,
Thank you for your Quick answer but this error was so before i change the display digitizer. I thought and hope with changing the Display this error is fix but after replacement already there.
Greetz Benny
Punteggio 0
Hi Guys,
Have somebody the same issue?
Is it possible to repair?
Regards Benny
Punteggio 0
Aggiungi la tua risposta
Benny sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 274
