Salta al contenuto principale
Introdotto il 19 settembre 2014, questo iPhone con schermo da 4,7" è la versione più piccola dell'iPhone 6 Plus. Identificato dai numeri modello A1549, A1586, and A1589.
4994 Domande Visualizza tutte
Replacement screen has Vertical Gray Lines
Just replaced my wife's iPhone 6 screen with one from iFixit and it has vertical gray lines. I tried reseating the cables. No dice. Tried unplugging battery for 30 seconds. Checked connectors for bent pins. Don't see any.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
3 Risposte
This is normally because of a pinch in the ribbon cable that has damaged data lines or the LCD cable was flexed at the LCD and broke connections.
I have also seen this in rare occasions if the digitizer cable is not properly seated.
Punteggio 0
2 Commenti:
thanks for your reply.. so does that mean this digitizer is hosed and i need a new one?
da
I just had that issue when I was replacing my screen and found the problem to be one of the connectors from the digitizer not being properly seated.
da
Either the above answer by chriswku03, or it's because the units enclosure is bent out of shape.
It is a pretty thin piece of aluminum after all, so it doesn't take a whole lot before its bent, especially if dropped.
Punteggio 0
I plugged in the original cracked one and it worked fine. iFixit sent me a new unit that works perfectly. Great customer service!
Punteggio 0
Aggiungi la tua risposta
timktran sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,341
