Salta al contenuto principale
Eighth generation of the Mazda Protege.
49 Domande Visualizza tutte
What are the symptoms of a weak ignition coil?
Why does my 1999 Mazda protege 1.6 hesitate to go when i accelerate immediately after any immediate stop? Is it something to do with ignition coil? I did hear a spark noise from the ignition coil area when i checked. Please advice me.
Questa è una buona domanda?
Punteggio 0
1 Commento
Thank you guys... Coils and new NGK iridium spark plugs on its way.
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
The symptoms of a bad coil are misfire or backfire,engine stalling, hard starting and smelling fuel while trying to start, bad fuel mileage and not starting at all. If you are hearing a sparking coming from your coil its more apt to be bad ignition wires .I would start by checking plug wires and boots Hope this helps
Punteggio 2
Risposta Più Utile
Weak coil will cause miss firing and hesitation.
Punteggio 2
Aggiungi la tua risposta
Vishnu sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 17
Tutti i Tempi: 3,424
