Salta al contenuto principale
Lanciato a giugno 2012. Modello A1278. Processore Intel con Turbo Boost. Fino a 512 MB di RAM Video DDR5
1624 Domande Visualizza tutte
MacBook blinking question mark folder after bump
macbook was in sleep modus.
apparently i hit my backpack somewhere and it has a bumo.
opend it, was just really unresponsive.
turn off
turn on
blinking folder with question mark
i put another working hard drive inside and the problem sussists
i plug an external drive and boot from there and everything is fine.
so the SATA cable is broken?
now the bump is on the opposite part of the hard drive location.. could some other part be the problem?
i hope it´s not the logic board...
Update
the hard drive WORKS, just not when boot internally through the SATA cable
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Check the HDD cable. It may loose or possibly damaged.
Pretty serious "bump" to dent the case that much.
Punteggio 0
3 Commenti:
Most likely the drive is also dead from such a bump if it was running (sleep mode) or even not running.
da
no, hard drive is working. i plugged it externally and it's fully operational.
da
You are very lucky!
da
Hi,
I had the same problem.
Your sata cable needs to be replaced. You can buy a new sata cable. It's a 10 min repair. I did it with the ifixit guide and it works since.
Punteggio 0
Aggiungi la tua risposta
theoctopusride sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 385
