Salta al contenuto principale
Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
LCD no working after replacement Is it the back light?
Replaced a damage LCD Screen with a new LCD screen once plugged in nothing turned on. no light or anything. iTunes sees the Ipad and everything but cant get access because of passcode.
I believe something burned out on the Main-board. Not sure if it has to do something with the black light or something totally different.
The pictures below shows main- board circuits the one targeted red seems like it burnt out would it be best to replace that?
Questa è una buona domanda?
Punteggio 1
4 Commenti:
That's black resin coating that component. Doesn't seem burnt to me.
da
that is the only one that looks like that though and the area around it looks like something happen.
am letting the battery of the ipad charge to see if i can put a light to it. Ill back back too you tomorrow.
da
so i was thinking maybe since i does not seem like a black light issues maybe is the lcd connector issue ill take a deeper look and get some pictures on here as well.
da
the problem is not from that Resistance it will be heat up because Short Circuit in light area look the Light Coil in right side from that Resistance problem is from that change it your problem will be solved 100%
da
Aggiungi un commento
3 Risposte
put a really bright flashlight on the back of the lcd and let me know if you see anything.
Punteggio 0
2 Commenti:
Ipad is on i put a bright led lamp light on the back of the lcd. I don't see nothing. i was hoping it was a bad back light but am not seeing any signs of that.
da
i have a possible way connecting it to the tv gonna give that a try to see if i can see something that may help me some how :?
da
Press home and power button for 7 seconds and let go both at once. You will be back to normal again if you have not fried the backlight.
Punteggio 0
1 Commento:
attempted that a few times i put it in restore mode and all. i didnt do a restore dont want to lose data.
da
Punteggio 0
Aggiungi la tua risposta
Dwight Phillips sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 401
