Salta al contenuto principale
The Samsung Galaxy S3 is a multi-touch, slate-format smartphone with eye-tracking ability, increased storage, and a wireless charging option.
459 Domande Visualizza tutte
My phone was dropped it works but the screen is black!
I dropped my phone onto a tiled floor and now all i get is a black screen. It turns on and i can get calls and listen to music but the screen is black. HELP PLEASE !
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Unfortunately it sounds like the LCD itself is damaged, replacing the whole screen would solve this. :)
Punteggio 3
2 Commenti:
having same problem but why does it sometimes work fine if it's burnt out? It's very annoying. If I flash a flash light right into the screen I can see everything else is working fine
da
@dawhoda this could be a backlight issue instead of a screen issue, but you should rule out a faulty screen first.
If it’s a backlight issue, you would need someone who can microsolder to fix your backlight problem. :-)
da
This happened to me and my phone wasn't dropped. I could just see screen faintly so went into settings and turned up brightness and it's fine. Hope this helps.
Punteggio 0
1 Commento:
Yeah this you can't even see at all unless you shine a bright flash light directly into screen at like an inch away from screen. My conclusion is the display panel is bad like couple people said. Thanks guys.
da
Aggiungi la tua risposta
alisha sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 382
