Salta al contenuto principale
Uno smartphone Android di Samsung per il mercato asiatico, con vari numero modello, lanciato nel dicembre 2014.
Why my phone cannot turn off?
y phone was suddenly hung-up when I open my email. I press long press to turn off but it doesn't work. It will not turn-off. How can I solve this one? I try to recharge my phone, it doesn't work also.
Questa è una buona domanda?
Punteggio 21
28 Commenti
holding the down volume button and the power button at the same time till the phone vibrates should restart it. if you have it plugged in charging and do this it turns the phone off
da
That was a fantastic clue. works perfect!. Thank You Dude.
da
Wow that really helped me thank you very much
da
worked perfectly. thanks much!!!
da
Amazing advice! Nothing else worked but this did. Thank you :)
da
Mostra altri 23 commenti
Aggiungi un commento
4 Risposte
Soluzione Prescelta
Press and hold the Volume down and the Power buttons. When the phone reboots, release them.
Regards.
Punteggio 33
21 Commenti:
Dat was really helpful. ..thanks!
da
its working thank you so much
da
its good idea..... thank u .....
da
good job...... i really like u......
da
it's work... thanks
da
Mostra altri 16 commenti
You could remove the battery and this will kill the phone and hope it boots properly when it restarts once you put the battery back in. Hope this helps and good luck
Punteggio 3
2 Commenti:
in samsung galaxy a5, you cannot remove the battery since the battery is built in.
da
Many, many thanks
da
unplug Charger before Turning off ,,
it turns off and doesn't reboot ,,
When it's already switched off..you can Plug in the charger and it won't turn on..
Works for me Samsung Galaxy j7 OS 6.0.1
Punteggio 0
Hello .. I forgot my lock pattern and when I try to hard reset it .. won't let me turn it off .. it wants the lock pattern in order to be turned off but I don't remember the pattern .. so .. no hard reset, no nothing .
Punteggio 0
1 Commento:
Thankyou so much. Totally worked. Only way to power off / shut down your malfunction samsung j 7 prime phone or device. Power & volume - key while its plugged in to charger. Or else it only restarts.
I was so lost, i felt the phone had malfunctions.
Thankyou so much
da
Aggiungi la tua risposta
Billy495 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 34
Tutti i Tempi: 60,251
