Salta al contenuto principale
Repair and disassembly guides for the Huawei Ascend G6.
20 Domande Visualizza tutte
My phone wont charge
i recently discovered that my phone will not charge after i had returned from a friends house and the battery had died so i put the phone on the charger but all that happened was a small red light flashed once above the screen and nothing else happened. this happened every time i placed the charger in the phone. i have already tried using other chargers and that didnt work so i tried cleaning out the charging port and that also didnt make any difference. any help is much appreciated.
Questa è una buona domanda?
Punteggio 8
1 Commento:
I just have the same exact problem and don't know what to do.
da
Aggiungi un commento
2 Risposte
You'd have to change the motherboard to get that fixed. They usually cost about 70$ CAD to fix. Easy enough if you have the parts and the tools. Best of luck!
Punteggio 0
1 Commento:
may I ask, what makes you say that?
da
Si lo conectais a un pc mediante el cable de mini USB y el pc no lo reconoce tal vez tengais el conector inutilizado por alguna cuestion como este dañado o desoldado en algunos casos....
Punteggio 0
Aggiungi la tua risposta
gerard holden sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,990
