Salta al contenuto principale
1.6 or 1.8 GHz dual-core processor, 2 GB or 4 GB of SDRAM, 64 GB or 128 GB SSD
Fan always going how to fix
My fans on my macbook air won't stop turning. They have not switched off unless I shut down the laptop or closed it. Its not over heating, the CPU is 0% and I have tried everything and nothing is working!!
Questa è una buona domanda?
Punteggio 2
2 Commenti:
Why/when/how did this issue arise?
da
Why you want stop turning fans? They must cooling down laptop its okay, or its to loud for you?
da
Aggiungi un commento
1 Risposta
The temperature sensor may be faulty ? Try installing a Fan Management App.
http://www.macupdate.com/app/mac/23049/s...
This will give you control of your fan speed but more importantly the temperature of your CPU.
Maybe it just needs a good cleaning to ensure it's cooling down properly.
Punteggio 0
1 Commento:
Unfortunately Fan temperature is OK. Apple Genius ran some tests and also didn't find any problem. I tried to clean it inside and still no result.
da
Aggiungi la tua risposta
moxno sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 6
Tutti i Tempi: 1,222
