Salta al contenuto principale
Modello inizio 2011, A1278 / processore i5 2,3 GHz o i7 2,7 GHz
782 Domande Visualizza tutte
Domanda Chiusa
Tools needed to replace trackpad
In the tools needed section in your manual it says to replace a trackpad I need a Y1 tri-wing screwdriver yet in the step by step procedure #5 it says to remove a 5.6 mm and a 13mm tri-wing to remove the battery. Will a Y1 that you are selling remove both screws? A little confusing. I already bought a new trackpad from you.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Yes, the Y1 driver included in this set will remove both of the screws for the battery on this model.
Punteggio 0
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 164
