Salta al contenuto principale
Processore dual core Intel Core i5 da 2,3 o 2,6 GHz o quad core Intel Core i7 da 2,7 GHz (fino a 3,7 GHz con Turbo Boost) con 6 MB di cache L3.
Using Late 2013 Logic Board to replace Mid 2012 Logic Board
Does anyone know if a late 2013 logic board 15-inch will work with a mid 2012 15-inch retina? I need to replace the logic board and wanted to see if the upgrade would work.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
This is a bad idea, don't do it!
Punteggio 0
The answer is no. Sorry.
Punteggio 0
1 Commento:
I'd like to know this, too, but would like to know specifics. Do you know why it won't work, or are you just saying it because the model years are different? You'd obviously need things like the display cable, antennas, trackpad/keyboard, battery, etc, connectors to match up. Do they not?
da
Aggiungi la tua risposta
Paul sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 286
