will the screen from a G71 fit in a G72
I need to know if the two screens will interchange
Questa è una buona domanda?
You must match the resolution, backlight, and screen size to your current screen. You cannot deviate from your current screen specifications. A screen with different specifications will not work with your system.
In this case--you should be able to, yes, as both laptops use identical screens with the same 40-pin connector. Worst case scenario, you're looking at about a $70-$75 part.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 165
