Salta al contenuto principale
Released in 2013 Model number: ONETOUCH 7024W FCC ID: RAD386
Why I can't charge my phone
My charger piece in the inside of the phone where i charge my phone is damaged how can i fix it
Questa è una buona domanda?
Punteggio 5
1 Commento
i want where to take phone it to fix the charge pots
da
Aggiungi un commento
4 Risposte
Risposta Più Utile
Hellow Caleb Ragsdale,
you can simply change the [http://daughter card |Why I can't charge my phone]
here is the teardown guide
if you have sound soldering skills you can change the charging port and it will cost around $2
Punteggio 3
Where do I find that for my phone can charge and how do I find it
Punteggio 2
how do i fix the charger port on on my phone it is broken
Punteggio 0
I had my prongs bent in by someone so I want to connect positive and negative inside to my charger wires BUT it has 2 red 2 black and 2 white, what to do? :( its a alcatel one touch fierce xl :( . + and - not labeled.
Punteggio 0
Aggiungi la tua risposta
Caleb Ragsdale sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 6
Tutti i Tempi: 1,229
