Ipad is not charging after using a half broken usb cable
Hi , My Ipad mini is not charging anymore, no matter what usb cable I use ,I had a half broken usb cable, I think its unstable voltage damaged somthing, now when I plug in my new cable it detects it, because the "no battery, plug in your charger" shows up without touching any button,but it wont charge,
https://support.apple.com/library/conten...
(this is what happens when I plug in my charger)
and sometimes the apple logo shows up and my ipad actually turns on(when I plug in the usb cable) with 2% battery, but even then it won't charge, what is causing this problem?How can I fix it?
Questa è una buona domanda?
4 Commenti
"had a half broken usb cable" broken where and how. It got nothing to do with unstable voltage and everything to do with shortening out.
da oldturkey03
some wire inside the cable was broken and I had to dance around my cable to find the spot that charges,
the whole charging process was unstable,even in that spot,because if a butterfly flyied the other side of the world,I had to find that spot again
da Azim Meygooni
and you now use a new cable and your iPad does no longer charge?
da oldturkey03
yes,and those weird things happenes
da Azim Meygooni
