Salta al contenuto principale
The second generation HTC One—dubbed the HTC One (M8)—features a dual flash and the new Sense 6 UI, and was released March 25, 2014.
Bad Wifi reception after LCD replacement
I bought a HTC One M8 with cracked screen. Today i replaced the LCD and i notice very bad wifi reception. Did i damage something or forgot something?
I don't know where the wifi connector is located, and can't seem to find the answer on the internet.
Questa è una buona domanda?
Punteggio 2
1 Commento:
I have the same problem now. If you know what to do, please write it down
da
Aggiungi un commento
2 Risposte
hi
The problem is that you simply forgot to install the reinforced tape signal for Wi - Fi.
see photo ===>>
WiFi fix
https://s22.postimg.cc/islbn1s69/wifi_fi...
Thank you
Punteggio 0
1 Commento:
Also this can be caused by damaged antenna connector or cable in case anyone wanted to know, but most of the time like you said forgot to put back the Wifi antenna cable.
da
I need help. I changed display and i have poor Wifi signal. I connected all that needs to be connected. I think that i damaged cablr, but i don't now which one is for wifi. I will probably buy a full new set. Please if someone know which cable is for what text me. Thanks
Punteggio 0
Aggiungi la tua risposta
Gregory sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 832
