adjusting deck height riding mower
mower has 6 height settings. it is cutting too short. how is deck height adjusted? 16 hp 42" cut 6 speed trans.
Questa è una buona domanda?
push the button on the long handle on your right and slide forward or back toward you to adjust cutting deck height
Even using the lever the deck has no height I have the same problem on my kgro
I have the same tractor. There are adjustable rods at the front that adjust height but not too much or the back of the deck is lower.
size oil for kgro power pro 18 hp 42 cut
kind oil use for kgro power pro 18 hp 42 cut
Adjusting the rods at the front helps but not too much of the back of the deck is too low.
I have to replace the blade drive belt so more head scratching to figure this out.
Pulling the deck off is a pain In the tush.
hope my suggestion helps.
I have the same tractor, it runs and all but the deck won't turn the blades. Does it need adjustment and how do you do it? Thank you.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 3,398
