Salta al contenuto principale
Domanda Chiusa
Flickering Screen, horizontal lines, varies in degree of severity
I have noticed in the last week that my screen has flickering horizontal lines that appear on the screen. When using the web, the problem becomes worse and often turns the whole screen dark gray / black.
Is there a fix for this that I can do myself? Possibly a loss video cable or something? As for having it repaired, it may not be worth the cost.
thanks
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
You say <<When using the web, the problem becomes worse and often turns the whole screen dark gray / black.>>
This symptom looks like a failing GPU (heat generated by streaming video on web). I would connect the PB to an external monitor and check if the video is normal on the external. If yes then the GPU is OK and the LVDS cable may be bad.
Punteggio 3
2 Commenti:
+ a distinct possibility
da
To test the GPU, plug into an external monitor, if the screen on the monitor starts doing the same thing at the same time as the Book, that will confirm it.
da
The most likely villain in this is the Display Data Cable (LVDS cable). Try moving the screen up and down and watch for greater activity of the lines while doing so. If it acts up then you need to replace the cable.
Here's the part: [prodotto collegato mancante o disabilitato: IF153-051]
Here's how to do it: PowerBook G4 Aluminum 12" 1-1.5 GHz Display Data Cable Replacement
Punteggio 2
1 Commento:
+ comprehesive answer
da
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 6,890
