What cain of transmission I have LSD or NO LSD,vin#JN1CA21D6TM419624
What transmission i have on
My 1996 maxima vin# JN1CA21D6TM419624 is it lsd no lsd...
Thanks
Questa è una buona domanda?
Thanks
arturo monreal, your VIN only identifies your vehicle as :"
VIN:
JN1CA21D6TM419624
Model:Maxima
Make (Manufacturer):Datsun, Nissan
Model year:1996
Manufactured in: Japan (Asia)
Sequential number:
419624
Body style: SEDAN 4-DR
Brake - front: Disc
Brake - rear: Disc
Driveline: FWD
Fuel tank: 18.50 gallon / 70.0 liter
Tires: 205/65R15
Trim level: GLE
The GLE was issued with a RE4F04A Transaxle The transaxle with LSD is RE4F04V. you could try this tip from maxima.org "Big driver's side axle seal and diff with no cross shaft in it (if you look through the axle holes and can see all the way through with no metal rod visible in there) then it's a VLSD trans." the other way would be look at the data tag on the firewall near the passenger side of the car. If it ends with a "V", then you have a VLSD. One more way to identify it would be by jacking the car off the ground. Then spin one of the 5-bolt output shafts and see if the other side spins the same direction. If it does, then you got a VLSD. If it spins the opposite direction, then it is not.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 21
Tutti i Tempi: 1,198
2 Commenti
Ok recently buy this car with no reverse and trying to replace the transmission bought one on junk yard and it's diferent than the one on the car now have the axle on driver side Lil ticker ,the one from junkyard matches the first 9 dijits on the vin # but where the axles go in it's like a pin inside Wich the one on the car don't have a pin ,., looking at all parts on car looks to me like they replaced it before maybe with the wrong transmission.. so was wondering if I have the right one this time sence the numbers on transmission and vin match.
da arturo monreal
"can see all the way through with no metal rod visible in there then it's a VLSD trans. that would mean that the car originally had the VLSD transaxle
da oldturkey03
