Salta al contenuto principale
A home electrical installation is a complex system of electrical components that bring power into a home and distribute it to the various outlets, appliances, and lighting fixtures.
24 Domande Visualizza tutte
Hot to re-solder the usb side of an Apple 30 pin cable.
Hi Vs Electronics - so you believe, that the following connection would be all right?!
Is there a change to destroy anything when I do it a wrong way?!
Thank you & Best Regards, Markus.
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Risposta Più Utile
Assuming it was made following standards (not a given) red is +5V, green is data-,white is data+, and black is ground, That's the order on the USB pins too - 1 is +4V, 2 is D-, 3 is D+, 4 is ground.
Punteggio 3
Aggiungi la tua risposta
markusstenger sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 321
