Salta al contenuto principale
A 32-bit fifth-generation video game console that was first released by Sega on November 22, 1994 in Japan, May 11, 1995 in North America, and July 8, 1995 in Europe.
22 Domande Visualizza tutte
No power after brief flicker of the power light
Hi
I recently purchased a Saturn from eBay and after connecting it to my TV it seemed to be fine but after a few seconds the power went. If I leave it for a while and try again the power led will blink green and then it just dies again.
Could this just be a fuse issue as I cannot see any obvious broken bits on the power supply board (I have no meter to test the fuse)
Any ideas?
Thanks
Chris
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
If you are doing repairs involving opening up a console, a multimeter is a must-have tool. From your description, I believe the issue is with the power board. I recommend checking the caps on the power board a second time. Do any of them appear bloated, even if they are not leaking? Normally, the top of the cap should be flat. (bloated caps can sometimes be missed if they aren't leaking.)
An issue with the fuse was my first thought, but if the fuse was blown, the Saturn wouldn't be getting any power at all.
Punteggio 0
Aggiungi la tua risposta
Chris Horne sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 7
Tutti i Tempi: 515
