Salta al contenuto principale
A home electrical installation is a complex system of electrical components that bring power into a home and distribute it to the various outlets, appliances, and lighting fixtures.
20 Domande Visualizza tutte
sprinker system irrigation valve box outside and located above ground
The valve box is full of water and some water is pooling on the ground outside of the valve box and it hasn't been used for over a year. I see wires inside is it an electrical hazard to touch? If the water inside box is not normal how do I repair? It hasn't rained that much.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
I’m not a professional by any means but I’ve done some work on the subject,, if there’s water in the box and it hasn’t subsided, that means there’s a leak somewhat, possible locations.
  • Cracked pipe
  • Solenoid is not fully closed
  • Screws on valve are not tight
Punteggio 0
Aggiungi la tua risposta
mwiggins sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 229
