Salta al contenuto principale
L'Apple iPhone 5s è stato presentato il 10 settembre 2013. La riparazione di questo dispositivo è simile a quella dei modelli precedenti e richiede cacciaviti e strumenti di apertura. Disponibile nelle versioni GSM o CDMA con capacità di 16 , 32 o 64 GB nei colori Argento, Oro e Grigio Siderale.
3530 Domande Visualizza tutte
Bluetooth problem after screen replacement
Hi everyone,
I changed my screen, there were no problems, but during reassembly I changed the screws fixing the cap for the screen connectors.
I changed the lower left with the lower right, and on the lower left side I felt a resistance while screwing.
I then realized my mistake and changed the screws into their correct order.
Since then I cannot make phonecalls in my car.
I can listen to music via Bluetooth, I can control the iPhone via car's controls, even the cars microphone does work, but cannot hear the audio from the phonecall.
Do you have any ideas what could have happened
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta Più Utile
Lower left and right screws are the same, this is not screw related.
Punteggio 1
Any chance you ever resolved this issue? I have the EXACT same problem and replaced my screen as well.
Punteggio 0
1 Commento:
Since I experienced this issue a few hours ago, I have no solution.
I guess that the digitizer is broken.
da
Aggiungi la tua risposta
mathiasparyla sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 4
Tutti i Tempi: 1,095
