Salta al contenuto principale
Model A1347. Released on October 23, 2012. Core i5 or Core i7 Processor. Apple Fusion Drive.
interchangeable Logic Boards A 1347 mac mini 2012
Heya,
I sent you an email a while back about Mac Mini late 2012.
I probably didn't phrase the question correctly. . .
I have a mac mini 2012 with an i5 logic board in it. . .
I would like to put in an i7 logic board in it instead. . . very long story. . .
is this possible? Are the logic boards for the late 2012 mac minis interchangeable?
Please advise. . .
Kind Regards
Rob
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Risposta Più Utile
Well you are between a rock & a hard place here ;-{
At this point I don't think it's worth swapping out if your system is working. You can buy a used system for less than the cost of a replacement logic board (approx $750 U.S.)
As to your direct question you can replace the logic board within the same series without issue. In this case the i5 logic board (Macmini6,1) can be swapped out with either i7 (Macmini6,2) models being an exception to the general rule.
Punteggio 3
Aggiungi la tua risposta
rob Stewart sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 571
