Salta al contenuto principale
Repair and disassembly guides for the Compaq Presario CQ40.
Why is my battery not charging
How i fix my loptap that cannot charge in if even the charger are conected my laptop doesn't work but if the battery is have charge its working
Questa è una buona domanda?
Punteggio 5
Aggiungi un commento
1 Risposta
Risposta Più Utile
Sounds like either you charger or DC jack is faulty. Ensure all leads are properly connected. Test your charger using a multimeter for the voltage given on the sticker on the charger. If you are getting the correct voltage, it maybe the DC jack which is a common fault on laptops. You can test the DC jack by opening the laptop up and testing for voltage where the jack meets the board. If the DC jack and charger are working, the power board is probably at fault.
Punteggio 1
Aggiungi la tua risposta
louieokford sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 10
Tutti i Tempi: 2,868
