Salta al contenuto principale
"Plugged in, not charging"
So the thing is, my laptop shows "Plugged in, not charging" all the time when I unplug charger, it shuts down. When I insert another battery everything is normal and charging, laptop working with battery. I already tried uninstalling battery drivers and install again, did not do the trick. Do I need new battery? Or maybe I can fix it myself? Added picture how it looks.
http://www.bildites.lv/images/3cpfbhd3hm...
Questa è una buona domanda?
Punteggio 0
2 Commenti
When you say shuts down, does it completely lose power and power off? Or does it go through the shut down process? Is the battery lock engaged?
da
We provide help in finding and replacing Samsung battery, if you are looking for same feel free to visit .https://laptopbattery.ae/samsung.html
da
Aggiungi un commento
3 Risposte
Risposta Più Utile
check your battery, this is a common way to tell your battery is bad.
Punteggio 1
You answered your own question, sound like a new battery is needed.
Punteggio 1
This is in fact a sign of a bad battery, how long have you had said battery? It is definitely in need of replacement no questions asked,
Punteggio 1
Aggiungi la tua risposta
alexjakob sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 1,873
