Salta al contenuto principale
GSM iPad 2 with 16, 32, or 64 GB of storage, and a Dual Core A5 Processor. Model Number A1396. Repair is complicated and requires heat and prying.
152 Domande Visualizza tutte
ZIF Socket Crumpled on iPad 2 Logic Board
Hello. I was attempting to replace my GSM antennae on my iPad 2 logic board following the instructions on step 38 on iPad 2 Wi-Fi EMC 2415 Bluetooth/Wi-Fi Antenna Replacement. Unfortunately, the ZIF socket was crumbled when i tried to remove the headphone and front cover cable.
Two questions: (1) can this ZIF socket be replaced/repaired and if so, where can I find some information on it and (2) if I didn't repair it and just left it unconnected, would the logic board still work but without a headphone jack and front camera?
Thanks!
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
to answer your questions, 1) yes it can be replaced, there are online services that you mail out too and they fix and ship back. 2) if left unconnected it would not effect the logic board at all just the components will not work but the software might act strangely when attempting to use those components. example using the camera.
Punteggio 1
2 Commenti:
Thanks, qpunk!!!
da
your welcome
da
Aggiungi la tua risposta
Bill Masco sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 167
