Salta al contenuto principale
Lanciato a giugno 2012. Modello A1278. Processore Intel con Turbo Boost. Fino a 512 MB di RAM Video DDR5
1624 Domande Visualizza tutte
Logic board damage - what is this component?
Hi.
I've recently discovered my MacBook's logic board was damaged, probably by the previous owner.
Picture 1 - Before cleaning
By the look of it, I guess it was Coke. After cleaning it with isopropyl alcohol, it looks like this.
Picture 2 - After cleaning
As you can see, two pins of the component in the red circle are destroyed, but the device is working properly and I haven't noticed any strange behaviour.
So my questions are:
What is this component?
Which circuit is it part of?
My plan is to buy a cheap broken logic board from eBay and replace the component. My technician friend told me that was a good idea, but that I also could use it like this, because it's probably ("probably" - this is what worries me) a component which is not that important.
Thank you in advance.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
That is U 5410 which is a TI INA214 in a SC70 package which is part of your computer sensors. This one monitors the high side current and "reports" it to the SMC. If you run a AHT it should give you a sensor error. Replace it to avoid any sensor related issues
Punteggio 0
2 Commenti:
Thanks!
Just to be sure, can this one do the job?
http://www.ebay.com/itm/IC-CURR-SHUNT-MO...
da
Some of the values are different so not sure how this will interfere with the function for the sensory circuit. I'd stick closer to he original values http://www.ti.com/product/ina214
da
Aggiungi la tua risposta
vektor42 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 82
