Salta al contenuto principale
Not enough disk space? Need a backup solution? External drives provide you with extra storage in your office or on the go. Learn how to repair them here.
334 Domande Visualizza tutte
Replacement mSATA connector needed
I have found that the mini usb port on my Samsung G3 Station had disconnected/been ripped off.
After removing the enclosure I have unplugged what seems to be an mSATA converter or something (pictured) and now I need to replace it.
Where abouts would I be able to obtain a fairly cheap replacement part in Australia?
Item specifics:
"Converter" - G3 Station 3.5" REVO.4 20100204
Hard Drive - Samsung HD154UI 1500GB +12V/+5V, 0.5A, 0.7A
Thanks in advance for any help!
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Bought a Digitech USB 3.0 to SATA adaptor at Jaycar after giving up trying to reattach it, had to cut a hole in the existing enclosure to fit the new part but works fine now.
http://www.jaycar.com.au/IT-Products/Con...
Punteggio 0
Got the exact same problem, any solutions?
Punteggio 0
1 Commento:
Sorry I didnt update the post, answer is posted now :)
da
Aggiungi la tua risposta
Alastair T sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 7
Tutti i Tempi: 2,341
