Salta al contenuto principale
Sesto modello di iPhone Apple, annunciato il 12 settembre 2012. La riparazione si fa in modo simile alle precedenti versioni di iPhone e richiede cacciaviti e strumenti di apertura. Disponibile con tecnologia GSM o CDMA, con 16, 32, o 64 GB, nero o bianco.
2522 Domande Visualizza tutte
My iPhone not connecting to carrier
I took my IPhone 5 to repairer just to change my broken screen , he end up changing including the battery that it was bad , now the my phone cannot connect with Tmobile but can connect with wifi .
Please can anyone tell me what to do ? Because I can't make calls
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Take it back and have them check the antenna cable. Sometimes they don't get seated properly after the screen is replaced. Did you check the SIM card. I usually clean the gold contacts on the SIM card. Your provider can also check the SIM card.
Punteggio 0
Have you checked the SIM card? He may have left it out or damaged the internal connector.
I was able to use an original Apple battery and do a Full firmware re-install to get my iPhone 5 working.
Punteggio 0
Aggiungi la tua risposta
Henry Musa sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 163
