Salta al contenuto principale
Western Digital My Passport Drive. USB 3.0 Portable External Hard Drive.
73 Domande Visualizza tutte
Repair my external hard drive?
I accidently dropped my hard drive and now it just makes a screeching sound and is not recognized by CPU. Can the data be recovered?
Questa è una buona domanda?
Punteggio 19
2 Commenti:
wd my passport i/o error pls help .
da
I have this issue and this was my backup!!!
da
Aggiungi un commento
2 Risposte
Hello There,
Make sure after dropping your hard drive, the inside parts are safe. Is it detected by the system if not then data recovery software will not help you to recover your data.
So i will suggest you to get and data recovery expert advise.
Punteggio 0
You’re going to need to bring this to a data recovery professional, its the only way to recover the data safely. Unfortunately, they cost a large amount of money.
I cannot stress how important it is to keep important data backed up on a separate drive for reasons like this. You never know when something can go wrong. Also, SSDs and flash storage are much more reliable so I recommend you use that from now on.
Good luck to you, and I hope you get your data back.
Punteggio 0
Aggiungi la tua risposta
J Guenther sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 14,609
