Salta al contenuto principale
Model M8413 or A1007 / 600, 700, 800, or 900 MHz G3 processor
36 Domande Visualizza tutte
What would be the max. HD capacity when replacing internal drive?
I want to upgrade the internal hard drive. It appears to be a 30 gb . How large can I go as far as storage and the ibook still recognize it? Also what type of drive should I be looking for. Example " ATA 2.5 inch"..
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Without jumping through hoops to get it formated, you should stay under 128GB. An ATA or IDE drive will work fine. Just stay away from the SATA drives. This drive will work just fine for you: [prodotto collegato mancante o disabilitato: IF107-024]
Here's a bunch of new IDE drives up to 320GB that will work for you: http://eshop.macsales.com/Search/Search....|0&N=6885
Punteggio 2
Aggiungi la tua risposta
James Brizendine sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 653
